Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3221 Questions View all
Why would my iPhone not charge?
my iphone 4 was working perfect yestarday morning. i charged it and it was fine. then later on at night i run out of battery and when i got home and try to charge it again. nothing happened
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Battery is bad. Charger is bad. USB cable is bad. Clean iPhone dock port with a clean dry toothbrush. Try to charge. If nothing, clean dock port with a bit of Isopropyll Alcohol, either using toothbrush again, or with lint free cloth. Especially clean the pins which are on top of the dock mid rib. Try charging it again. Keep charging and try Reset, hold both Home and Power buttons until the iPhone restarts, usually less than 20 seconds.
Score 3
Add a comment
Add your answer
romina will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 530
