Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3215 Questions View all
Power Button Stuck, Doesn't operate
The power button is basically stuck down and will not function the switch. Is this more likely a power button replacement or a Power & Sensor Cable replacement? (which parts should I buy)
Or is it an indication the power button bracket is broken? (no repair listed) The phone was dropped.
Comments:
No one else have a inoperable power button?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I had the same issue and I can tell you that you just need the cable cuz the button bracket is broken. I just replaced my cable and I have a working sleep/wake function :)
Comments:
Worked, tough repair but I am set now. Tks
by
Add a comment
Awesome. Thanks I'll give it a shot
Add a comment
Add your answer
jimmora will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 2,327
