Why does my playstion turn on but then when I’m playing it turns off?
My PlayStation 4 for the last month or so has been not wanting to turn on but when it does it turns off when I’m playing a game, is there a reason why?
@dlo98 …sounds like an overheating issue. when it turns of, does it beep or show a red light? if so, its recognizing overheating. if not, it still sounds like a component heating up and shorting the system out. can do some troubleshooting here:
this is a teardown of the system. follow this until you have access to the fan and housing. (and the apu as for the next step) make sure to clear any debris and clogs.
next clean and replace thermal compound. follow this guide here (applies to most systems. be sure to only apply compound where compound already exists):
if it is due to components heating up and shorting, the apu is usually the culprit. follow this guide to fix:
PlayStation 4 Turns On Then Back Off Repair
these solutions should clear this issue up, in the case it doesnt…post back for further assistance.
Guide
Difficulty:
Moderate
5 - 20 minutes
Guide
Difficulty:
Moderate
Guide
Difficulty:
Easy
10 minutes
Sounds like it's over heating. Take it apart and clean it!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 62
I also have another question, my ps4 sometimes doesn’t want to turn on why is that ?
by DavidLo98
could be related to the shorted component, if the unit is completely dead with no signs of life, typically would indicate a power supply issue. if the unit is shuting down without giving you the indications of overheating...id say this is the cause of both issues. if it is giving you indications of over heating, i.e. red flash, threes beeps, screen saying unit has overheated, it would be in conjunction. at this point with the new information, id start troubleshooting the power supply. use the teardown to get to the power supply, then open it up and look for any signs of failed components. bulged capacitors, burnt components....yada yada. while you have the device apart, still wouldnt hurt to change the thermal compound and clean the fan and housing.
by jostewcrew
How to fix fana
by Kere nabil
