First generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
126 Questions View all
What type of glue is used to stick battery into inner rear case?
What type of glue used to stick a new battery into an Ipad inner rear case?
If I use any type of glue it may result in melting the battery or case health issues later?
It may even come unstuck later and rattle around when closed up!!!!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I would suggest using rubber cement. It doesn't produce heat when curing. Also, the battery and glue will be removable if the battery ever needs replaced again.
Score 3
Add a comment
Your best bet is to use a petroleum based glue, which is the glue they actually use in the iPad. It's good stuff as it won't react with the plastic (also made from oil!) and damage the battery in any way. It also means you can clean away all of the glue very easily using a petroleum based solvent, this stuff will get the glue totally off and will evaporate off too, this makes sure there is no moisture at all in your iPad which could damage it, unlike other glue products.
Add a comment
Add your answer
tngraph will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 500
