Popular laptop sold by HP. While it comes in many configurations, all models of this laptop have the same basic form factor. The numbers after G60 indicate the factory specifications of the laptop and who sold it.
51 Questions View all
does my hp g60 230us laptop have both the lcd power inverter cclf?
I just looked up my lcd sreen for my computer and I know what I have to do but my question was or is can my power inverter that powers my lcd screen and backlight be replaced or do I have to by a new computer?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
In the case of your computer it is necessary to replace the display inverter, release the display inverter 1, located at the bottom edge of the display assembly, from its mounting clips. The maintenance guide is available here. Hope this helps, good luck.
Score 1
Add a comment
Most Helpful Answer
Yes. You can replace the inverter. Sometimes its behind the LCD screen or in the frame. ( you would need to know if the inverter is the problem, assume you already do)
Score 1
Add a comment
Add your answer
Tj Jones will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,620
