Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
5197 Questions View all
charging on pc not recognised after motherboard change, with og cable
just changed my iPhone 6 motherboard. its charging when its powered on while connected to the laptop but when i put it into recovery or DFU it says device unknown. i’m using an original cable changed the motherboard 2 times same problem. could it be a hardware connection i’m missing, if yes then where.
thank you for your time and i would appreciate any solution suggestions.
Add a comment
1 Answer
I would try a new charging port. Why did you replace the motherboard?
Add a comment
Add your answer
Treezy Lit Squad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 20
