The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
243 Questions View all
Is it posslible to change the LED?
Hi there,
i´d like to have an other colour in the back and menue keys. Is it possible to change the (i bet its only a single one) led behind them? You don´t open the galaxy s2 this far.
Thank you for your Answers.
Greets Kevin
Add a comment
1 Answer
Chosen Solution
if you can open your phone to the led then you should be able to desolder and resolder any colour you like...finding one the same size is the only problem.
Score 3
+ Hi Polly, good answer. LEDs sizes are given as diameter measurements in mm (millimeters) and voltage. Measure the voltage going to the existing LED and it's diameter. Purchase accordingly.
I found some of these ages you do.. thought they looked like fun, have seen many bigger ones being used with tiny battery and magnets on just never had anything i needed a small LED for..
Add a comment
Add your answer
Kevin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,950
