Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
271 Questions View all
USB/Ethernet/all ports not working
The USB/Ethernet/all other ports on the back of my iMac have stopped working. I plugged a USB cable in and it touched a lamp with a short--it arced and now the USB and Ethernet don't work. The computer boots seems to work fine, but I can't interact with it via keyboard/mouse/ethernet. The airport is off so I can't try connecting via wifi.
My guess is the bus with the ports has been fried. Is this on the logic board, or is it a separate board that's easier to replace?
In addition, any ideas on how to connect/interact with the computer without the use of USB/Ethernet/Wifi?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
You're probably looking at having to replace the logic board. You may be able to get to the bluetooth by disconnecting your keyboard and starting up.
Score 1
Add a comment
Most Helpful Answer
if you have a bluetooth module, you can try using a bluetooth mouse and keyboard. your imac should ask you pair a keyboard and mouse if you have the bluetooth installed.
as for the damage, the ports are part of the logic board. i have never seen the come seperate. i would have to say
Score 1
Add a comment
Add your answer
Reed will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 898
