Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac Mini Server configuration.
176 Questions View all
Server with only Apple SSD then add a second spinning drive?
If I get the Mini Lion Server with just Apple's SSD installed can I just add the second hard disk? Are the cables and or connections already there? Do I need a kit? Is the one for the non-server mini what I need?
Regards,
John
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
A server version of the Mac Mini already has all the necessary cables, as well as two drives. If you're asking if you need to purchase another hard drive, the answer is no, unless you want to upgrade the HDD already there. Our dual drive kit is for non-server models, which only have one hard drive (specifically, the top one). Our kit is an alternative to purchasing a server model, because you can install any second hard drive you wish, whereas the server model from Apple comes with both drives already.
Score 2
Comments:
you can then install a HD SSD in a mac mini basic server?
you would say yes
Thanks
*sorry for english
by
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,044
