Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
60 Questions View all
Replace the MacBook Pro 2019 keyboard
my macbook keyboard doesn't work, because I don't want to replace the warranty period, I searched for references and haven't found it yet.
Add a comment
1 Answer
I would strongly recommend you rethink your direction here!
Apple offers an extended warranty program for butterfly keyboard failures. If you have a bad key or multiple keys Apple will either fix the single key of replace the entire uppercase with a new keyboard.
Replacing a keyboard is quite an intensive a project! In Apples wisdom they rivet the keyboard in! So you’ll need to drill out the rivets without damaging the uppercase, Then you have the next problem which is finding the 4 Generation keyboard which is what your system had.
In the end you’ll spend a lot of time and the results won’t be as good as what Apple’s uppercase rebuilders can achieve with custom tools and lots of experience! If they mess up it goes into a trash bin and move on, what are you going to do if you mess up?
Add a comment
Add your answer
asreds.claten will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 25
All Time: 689
