Not turning on just beeps
as soon as i plug my machine in it has one light flashing with a fading beep every 1-2 seconds if I press and hold the power button all lights flash and has same beeping this even goes on for a good 3-4 minutes after I unplug it
Update (02/13/2020)
This is what it's doing
Hi @ashleyy11 ,
What is the make and model number of the washer?
by jayeff
Number is worn all I know is its a simpson 7kg
by ashleyy11
I think its a eziset750
by ashleyy11
Hi @ashleyy11 ,
Is that the green 'Power" light on the washer that is blinking when you first connect the power? Bit hard to see on the video.
Also did you check on the back of the machine up near the control panel for the model number on the compliance plate, as all the Eziset 7Kg models that I can find have a LED display window as well as control lights so not sure it would be correct for your model?
Have you proved that the wall power outlet is OK by plugging in another appliance (hair dryer etc) and making sure that it works OK?
by jayeff
Havnt tried anything else in Wall outlet but have tried machine where fridge is plugged in with same results
by ashleyy11
Show 4 more comments
