Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2688 Questions View all
Screen goes black after water damage
Hii, so this happened to me- My phone fell in water and right after it worked for a short time and then screen went black, I could still hear noise likea phone call.. so the problem was in a display. I turned it off and put it in rice for 2 days. I tried to turn it on and it worked.. and then it went black again. I used itunes to completely restart the phone again and it worked until i tried to bring brightness up and it went black. I’ve tried to make it work again but so far nothing. I do plan on visiting service shop but wanted to try on my own first. Does any one know if it’s possible to fix this on my own?
Add a comment
@ida0809 take it out of the rice. IT DOES NOT WORK This is a myth that really has to disappear. Skip the rice. It is absolutely useless.''' It will not help you fix your phone. All it does is that it provides a false sense of security. It will not clean your phone, it will not prevent corrosion.
Second, stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using these guides . You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad LCD and replacing the display assembly may fix it. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Add a comment
Water damage is commonly seen with iPhone series, which can result in different issues. You are likely to lose the data in your iPhone after the liquid damage, too.  So please treat it carefully.
And, rice can do nothing for your phone!!!
Add a comment
Add your answer
Ida will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 46
