Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1500 Questions View all
3Gs earpiece does not work, proximity sensor works.
My jailbroken/unlocked iPhone 3Gs - earpiece does not work.
The proximity sensor works.
The speaker works.
The headphones work.
Everything else works fine.
I took it to a local repairman and he tried a replacement earpiece but could not get it to work and told me that he thinks the problem was the connection at the logic board or software.
I've researched since, an it seems to be pointing to the #3 connector ribbon but I am puzzled by the proximity sensor still functioning.
I'm a newb and need some input from someone with experience.
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
A damaged Flex Cable #3 or damaged Connector #3 on Logic board may still have partial function like you are experiencing. The individual traces or components that are damaged, are broken, the ones that are not damaged still can work.
First step is to Replace Flex Cable #3, when you are there you can check with a voltmeter for conductance across the earspeaker. Also look for damage to the #3 connector on the Logic Board.
If still problems could be a damaged #3 connector on Logic Board as the repairman told you.
Add a comment
Replacing the #3 cable is rather tricky and I didn't manage to find a good description. So having done it, here is what I did:
This is tricky but doable and a lot easier than removing the glass to get to the clips as I saw on one YouTube video.
Add a comment
hi, i've replaced the flex cabel #3 and earpiece and still don't works..
Add a comment
Add your answer
Robert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,773
