Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
877 Questions View all
Can I use the back panel from a 5th Gen iPod Video?
I've had a broken 80GB classic buried in my closet that I found yesterday (I think it came with a lot of broken iPods that I bought a while ago, and didn't have the parts to fix at the time) It has a bad hard drive, and I left it partially disassembled, because I pretty much destroyed the back panel when removing it. I have the back panel from a 5th generation iPod video, and was wondering if I could use that as a replacement, if I bought a new hard drive. (Though it would be improperly labeled) Also, can I use any size 1.8" ZIF hard drive, or am I limited to 80GB, 120GB, or 160GB? (Apple's limitations)
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
The back panel will NOT work since it has different clips and is of a different design. The 6th generation (Classic) and 5.5/5th gen (Video) hard drives are not cross compatible. The largest drive for that particular iPod, that I know of, is the 160GB due to the interface.
Score 1
Add a comment
Most Helpful Answer
Replace the hard drive, you may fix it and yes, you can use the video's, I believe the headphone jack will work too
Harddrive wise, you can use any 1.8'' ZIF drive
Score 1
Comments:
please check your source and let us know.
by
Add a comment
Add your answer
Chris Green will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 697
