Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Goes into sleep mode upon boot-up, following spill recovery
Well, I spilled about 2 ounces of tea on my MacBook (in the upper left-hand corner where the chips are) - and it went dead in about 6 seconds, before I could grab and turn it upside down. I disassembled, removed RAM and blotted up the few drops of moisture I could find, blow-dried it, and let in sit 24hrs in open air. I then reassembled.
On AC power, with a full-charged battery, I get to the chime-tone, and see the OS X box with the loader bar, then the screen goes dark and power light blinks, apparently going into sleep mode. If I hit the spacebar, the DVD drive makes the normal sound and the power light stays on for a few seconds, then goes back to sleep mode. (The screen stays dark.)
Where is the sensor that puts the system to sleep? Might this be shorting out? Any other thoughts? Thanks in advance!
Score 1
Add a comment
Chosen Solution
See
this post with the same problem.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Score 1
Add a comment
Most Helpful Answer
Try running the Apple Hardware Test.
Score 2
Add a comment
Add your answer
Bill will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,945
