MacBook Pro models with 13" displays
4950 Questions View all
Can I boot to windows on a external harddrive?
i have a old hp computer and it run on windows 7 so i took out the harddrive and wondered if i can connect it to my mbp and boot it to that harddrive or does it require some driver or something?
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
You can use rEFIT to boot into Windows, but don't know how reliable this is, or you can create an image of the Windows Drive and then restore that image to a bootcamp partition. OSX needs to load certain drivers in order for windows to work properly and bootcamp facilitates this. To create an image of the Windows drive use "WinClone".
Score 2
Comments:
Answered the OP's question. +
by
Add a comment
As far as I can tell, it may or may not work, you can get a enclosure for it and try
Comments:
That's a big help.
by
Add a comment
Your Windows installation was configured during setup for the hardware of your HP and would not run using the hardware of your MPB. That does not mean you cannot get the data. Simply purchase a USB drive enclosure (without a drive already inside) and put your old drive inside and use it like any other external USB drive.
Laptops have 2.5" drives and desktops (your HP?) have 3.5" drives. Also there are IDE and SATA type drive/enclosures and you need to buy the proper one. Your SATA drive won't go in a IDE enclosure. Since you said it was a Windows 7 PC it's easy to assume it was a SATA hard drive ...but when we assume we...
Remove the drive from the HP and look at the data connection [not the power]. A wide flat ribbon is IDE and a skinny cable is SATA. Enclosures can be cheap online and they make some that can handle both types. Do a Search for -> 3.5 USB enclosure The word "enclosure" being the key word as you will otherwise come up with USB drives that already have drives in them. $20 -$49 Higher than that likely means it has a drive inside that you don't need.
If you are insistent on running the HP on the MPB, try VMWare or some other O/S virtualization product. The HP would have to still be operational to capture a Virtual image.
Add a comment
Add your answer
mop2011 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 763
