Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
Sound problems with I phone?
Heres the problem: I did an update for my iphone using a usb cable and itunes on my computer. Once the update was finished, I unhooked the device. Every since then, my phone has been saying "this accessory is not optimized for this device" and I can not get the volume to work right. When I try to change the volume, it is blank under the word "ringer" and the speaker on the screen. Does anyone know how to fix this?
Add a comment
1 Answer
Chosen Solution
This can be either a Hardware or Firmware issue. You are not alone as there are hundreds of other iPhone users experiencing the same issue. Try reading this on an apple forum. Some possible fixes include -
- Plugging earphones in and out of headphone jack about 20 times. Some iPhones are shipped in "earphone mode" and need to be reminded that THEY ARE NOT
- Clean out dock port (possible dust has gotten inside and corroded port making iPhone think it is connecting to something continuously ) and completely restore iPhone. Use a dry toothbrush (something small with bristles to do the job) or dry compressed air. DO NOT BLOW on it with your mouth as saliva may get into it and make it worse.
- Disconnect the battery for several seconds and reconnect, this will physically reset ALL electronic parts of the iPhone. Repair Manual HERE.
- Upgrading to the new/latest iOS
If none of those options have worked then you will need to either take your iPhone back to apple for a replacement (if still under warranty) or replace the dock connector, Repair Manual HERE
Hope this helps :)
iPhone 3GS Battery Image
Guide
iPhone 3GS Battery Replacement
Difficulty:
Moderate
20 - 30 minutes
iPhone 3GS Dock Connector Image
Guide
iPhone 3GS Dock Connector Replacement
Difficulty:
Moderate
Score 2
Add a comment
Add your answer
Steven Kelley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 440
