Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
568 Questions View all
I'm trying to upgrade the CPU/processor but I don't know where to buy
So apparently I can upgrade the CPU to 4.0GHz quad-core Intel Core i7 but I am new to all of this and have no idea where to buy it. Which one is compatible with my computer and from which reputable, trusted store?
iMac (Retina 5K, 27-inch, Late 2015)
3 Comments
Which store? Which country are living in?
by
Any store lol that’s the point. You tell me. I’m in USA @aactech
by
@empire233
Hi Blaine,
In USA Amazon or Newegg should be fine for online. I have ordered from both of them. No problems. I don't know your computer "brick & mortar" stores so comment. But did shop in Tigerdirect in Toronto but no good for technical help in store. Anyone?
For other people:
In Canada, Canada Computers - good technical help in store
In New Zealand, PBTech - good technical help in store
are good brick& mortar and online stores, in my experience.
The computer "brick & mortar" stores are good because of technical support and ease of returns.
by
Add a comment
Most Helpful Answer
Take a serious look at the guides before you even try. This isn’t like a PC where it doesn’t involve major surgery and you can revert back without a major disassembly plus information is easier to come by - even if it’s official validation data provided by support in a forum. The job is a total PITA on the iMac and Apple isn’t open about it and actively goes out of their way to hide it. This guide should give you a good idea of what you’re about to attempt - make your judgements carefully since any system damage will be $$$ expensive to correct. It’s doable, but can only be pushed up to a 6700K, which may not be enough of an improvement to justify the significantly more difficult install. Compare it to your *current* CPU before buying anything.
Your money will be better spent on RAM and an SSD. Most people get a system with a CPU that performs so closely to the original it's not worth risking needing an expensive motherboard to gain a marginal speed bump. It only ever makes sense if you got a i3 one and are willing to go all in and max the CPU out.
iMac Intel 27" Retina 5K Display Hard Drive Image
Guide
iMac Intel 27" Retina 5K Display Hard Drive Replacement
Difficulty:
Moderate
1 - 2 hours
iMac Intel 27" Retina 5K Display Logic Board Image
Guide
iMac Intel 27" Retina 5K Display Logic Board Replacement
Difficulty:
Difficult
2 hours
iMac Intel 27" Retina 5K Display RAM Image
Guide
iMac Intel 27" Retina 5K Display RAM Replacement
Difficulty:
Easy
1 - 5 minutes
Score 2
Add a comment
@empire233 the processor to use is a 4.0 GHz Core i7 (I7-6700K) . check the answer by @mayer on here Upgrading Processor on Late 2015 iMac 27 and read through all the comments. As for where to buy; the choice is yours.
Score 1
3 Comments:
Yeah but any good places you’d recommend?
by
I'd stick with places like Newegg.com or Compsource.com but that is just me
by
It's still a expensive CPU even used if you get the 6700K. I wouldn't go less then the max (6700K) due to the work required to change it out here.
I don't know if you can buy them new anymore - production ended in 2017. It may be an eBay thing now. They moved when they were set to cease production due to the artificial W7/8.X update lockout since there wasn't much to gain by going to 7/8th gen at the time other then artificial OS lockout.
Now that we're up to 10th gen, they're 5 generations old and all likely used. Used isn't necessarily a bad thing - it's still a good option.
by
Add a comment
Add your answer
Blaine will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 130
