2.3L 4cyl or 3.0L V6, 6th Generation
310 Questions View all
How to fix window and lock unit on front driver side door?
My window on the driverside front door I believe came off the track. How do I go about to replace the track and get it operational? Also the door lock doesn't open either. I think that something from the window track is blocking it as I cannot use the keyless entry remote or manually with the key. How do I fix this issue as well?
Add a comment
1 Answer
Chosen Solution
I made a copy of the part the shows you how to open the panel and how your glass and lock are positioned. Feel Free to download it from here. There are just to many individual steps involved and it's easier to read. Let us know if this helps, good luck.
Score 1
Thank you! I
Can you Upload Again, I canot see, Thank You for help!
I got this message when trying to access it.
You (account name 'aclark20') have just tried to access a document in another KeepandShare account 'oldturkey_manuals'.
To view it you need to ask the owner of the other account to set the Sharing controls to give your KeepandShare user name 'aclark20' rights to view the document.
Can you add aclark20 ?
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,171
