First generation of Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
80 Questions View all
How to replace SIM module?
Hi Guys,
I tried to replace a SIM Module for iPad 1 Gen, but it can't find the 3G signal yet, I would like to know whether the logic board locks the module while replacing the modules or not, if yes, how to unlock it?
Thanks a lot.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
I would bet the IMEI was blocked somehow or the antenna is bad
Check the IMEI, if it is blocked, the only legal way to fix it is to swap the logicboard(I would suggest changing it, but it turns out it's not legal, even if it is done as a personal fix and you aren't selling your device, DO NOT DO THAT!)
By all means if it isn't, the 3G antenna could be bad, change that
If it still doesn't help, your only hope is a logicboard(legalities changing the IMEI)
Score 1
Add a comment
Add your answer
apple5808 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,178
