Model No. A1367 / 8, 16, 32, or 64 GB capacity
1283 Questions View all
water damage/ will only work with mains outlet
my son was playing with my ipod touch 4th gen and somehow dropped it down the toilet, i didnt touch any buttons and put it in rice in a warm place for a week....turned it on and all was well for about half an hour when it suddenly turned off, i thought the battery was empty so i put it on charge and it all worked untill i pulled the cable out of the ipod and it went straight off.
i tried to restore it but it only gets power from the wall socket not the usb so thats a no no.
is it toast?
Score 1
Add a comment
Chosen Solution
john, I would follow this guide first. After you got it cleaned and evaluated, change the battery for sure. You may have to follow this guide iPod Touch 4th Generation Teardown to get to the battery.
Score 3
Add a comment
This is replacing my old awnser!
I would think it is the battery, they are cheap enough it is worth trying first with a high success rate trying, but you need to solder
To make the battery even more likely to work and avoid any more damage, take the iPod apart, put the logicboard in Isopropyl alcohol(99%) and clean the connection for the camera with a q-tip, that should never go in
Score 1
Comments:
In reguards to the display, i don't suggest doing that, but that is up to you, a q-tip is strongly recommended to clean the connectors on the display, to each thier own
by
Add a comment
could you replace the battery without replacing the screen?
Add a comment
Add your answer
john will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 570
