Can I use it as a display?
The computers logic board is finished, how can I rig it to work only as a display?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
In short you can't, no easily. You'd need to disassemble and figure out a way to connect the cable that normally goes to the logic board to some sort of adapter. My french is horrible but apparently this thread http://forum.macbidouille.com/index.php?... is all about figuring that out. good luck.
Add a comment
Typically you can't.
Add a comment
No, It can be used only as output for the motherboard. You may want to think about getting another Motherboard.
Tim
Add a comment
You might be better off selling the unit for parts, and taking the money to buy a new 20" monitor :(
You'll probably end up with some leftover cash in the process!
Add a comment
I agree with David, its much simpler and you'd be better off selling it for parts (if iFixit for example!) and then putting that money into a real, newer display.
Add a comment
Add your answer
geomatrixx will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,546
