Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
won't connect to my wifi at home
my iphone will not connect to my wifi at home unless i am in the same room with the roter. do i have an antenna issue on the iphone?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
take the phone apart and check for loose connectors
If all connectors are secure, the wifi antenna may be bad or the wifi board in it which I believe is on the logic board
Score 1
Comments:
Guessing is misleading to the person that is asking. the question here is for a 3G not a 4 or anything else.
by
Removed any 4 related sidenots and notes, but the 3G was never plagued with antennagate
by
Add a comment
Nick, I believe is correct. Since you are getting reception near the router, the connector is loose from the Logic Board. The connector for wifi is Connector #6, carefully reseat this connector to the Logic Board.
Add a comment
Add your answer
charles head will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 865
