This Sony 60-inch television produces natural color and outstanding brightness due to 3LCD technology. The Sony WEGA Engine used in this Sony projection television gives you complete picture clarity from any compatible video source by minimizing the digital-to-analog conversion process.
8 Questions View all
Why is my Sony Barvia 60" the flashing red 6 times constantly
How can I fix my tv I've tried to unpack.ug it but it's on a wall I've tried to tune it on and for like 1 milisecond it turned to just Sony the no picture blank screen and constantly flashing red 6 times I just need it fix asap thanks
Add a comment
1 Answer
Most Helpful Answer
Deanna Warr we need to know your exact model. For the Sony Bravia a 6 blink error code is usually related to a backlight issue. This can originate from the main board, or the power supply as well as other issues like a failed backlight array. You will need to remove the back cover from your TV and check the boards for obvious damaged components. Check the voltages going from the power supply to the main board as well as to the LED connectors. Post some good pictures of your boards etc. so that we can see what you see. Adding images to an existing question
Score 3
Add a comment
Add your answer
Deanna Warr will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 106
