Fix Your Stuff
Right to Repair
Store
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
530 Questions View all
iMac 24" Black Screen
iMac 24" 2.4 GHz We push the power the Cd drive spins and nothing else. Pulled the hard drive everything is there and working. Just turn off
Score -2
Comments:
Can you give us more information? What speed is it? Did you do anything before it stopped booting? Can you boot off a CD?
by
Which 24" iMac is it?
by
Add a comment
Chosen Solution
I'd check to make sure it's not the LCD by booting the iMac connected to an external display. If you get nothing on the external then you can rule out the LCD and see if its a logic board or video ram issue.
UPDATE:
If you're not getting video on an external display this starts pointing fingers at the logic board, or possible fans and sensors. My 24" iMac crashed about 4 months after purchase and then would hang on boot, turned out to be the fans and temp sensors.
If you have applecare take it in.
If you have another mac, try booting your imac while holding T to boot in target disk mode. and connect via firewire to another mac, if it works you can backup your files before sending it to apple,
apple doesn't really guarantee your data if you take it in under warranty.
Score 3
Comments:
There is no signal on an external display.
by
Add a comment
Most Helpful Answer
Interesting problem... Without more information it will be hard to diagnose. Based on what you have said though, it could be that your power supply isn't supplying enough power to the computer to start everything up. I hate to say it, but if it's not that, you probably have a bad logic board.
Score 3
Add a comment
You could try clearing the parameter ram.
Hold down Command + option + p + r and power the system on. Keep holding until it resets again.
This just resets the hardware and reinitializes everything so its fresh.
Score 2
Comments:
I have tried the Hold down Command + option + p + r and power.
by
Add a comment
Do you see any video? Maybe screen on your iMac is acting up.
Comments:
There is know back light or any thing on the display.
by
Add a comment
Does it chime? Or you just hear the CD drive spin before it quits? If no chime, not much else is going to happen in terms of resetting PRAM as others suggested. If it was a G5 model I'd holler about the capacitors (LB or PS.)
Comments:
No Chime I think it is the Logic Board or power supply. Thank you for your help
by
Do you get any POST indication? IOW when it won't start up, does the power light do any repetitive blinking?
Since you've opened it up, can you attempt booting it while it's open? Older iMacs had some diagnostic lights inside on the logic board.
by
Add a comment
I got the io board replaced and it is up and running. Thanks
Add a comment
I am having the same problem with my 24" iMac. The LCD is black. Maybe replacing the io board will work for me also.
Add a comment
What is an I/O board? Is it the Logic board?
Add a comment
http://www.youtube.com/watch?v=zU9wflqbp...
I have the same problems.. you can check them in the video above :((
please does anybody know what is wrong... only 3 years old and allready failing.... this cannot be real!
Add a comment
Add your answer
Support42 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 8,019
