Black screen, ext monitor works fine, invertor or screen?
Hi
Ive read similar problems on here but have not found answers soooo...
I have a Mac Book Pro 15"Core 2 Duo A1226
I bought it late 2007.
I put the laptop into sleep mode. The screen has never worked since.
It works fine if I hook up an ext monitor.
The computer boots up, chimes and even makes the zooming 'blip' sound of Skype starting up.
If I shine a light at an angle at screen I cannot see anything.
I have replaced the LDVS/ Data display cable with a new one but to no avail...
I have been told several options. Broken Invertor board or broken screen. Can anybody suggest based on the above info which it could be ? OR what tests I can carry out to define what the issue might be?
Any help gratefully appreciated!
David
Add a comment
1 Answer
Chosen Solution
The light at an angle will reveal a bad inverter if you can see the screen. You did the right thing by replacing the LDVS cable if you know it to be good from a reputable seller. Next thing is the screen. Check your work on the cable first. There were three different screen providers so make sure you order the exact replacement.
Score 3
Comments:
Thanks Mayer! Will have to pop it open again and look at the exact screen type and then find somewhere reputable to get one from. Will let you know how I get on!!
by
Add a comment
Add your answer
David C will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 558
