Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
Dim screen Not 6r8?
I have a 3gs with a dim screen so i figured 6r8 coil i have done 2 before so i knew the symptoms. I replaced it and it still has dim screen i even tryed a different coil and still dim screened what else could it be?
Add a comment
Chosen Solution
3GS backlight issues seem to be caused by Display LCD, 6R8 coil, or IC 109B. If your LCD Display is good, then hopefully it is the 109B chip. This chip is right next to the coil.
Score 1
Comments:
I used one off a junk board and when I went to take the chip off my good board i pulled off one of the two pads underneath!!! Is my board junk now??
by
Can anyone help me?
by
Jared check on this Anyway to reattach solder pads? and click on the link provided by ABCellars. Little bit more on the repairs possible right here http://home.comcast.net/~machrone/bjr/mi... but definitely not as neat. Good Luck
by
Add a comment
I think you need to comfirm your 6r8 is original, since many seller online sell 6r8,but a little bit difference with the one on the 3GS motherboard
I check a site ,the picture is same as on 3GS motherboard, and I get the items from them, it is original and can work
here is the link
http://wiisingonline.com/iPhone-3GS-6r8-...
Add a comment
Add your answer
Jared will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,514
