Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Questions View all
Red battery screen with white lines. Battery, screen or logic board?
My iPhone 5s is stuck on the red battery screen but at the same time shows white square and vertical lines.
It refuses to go beyond that screen. Putting it into DFU mode was a non helper as wel.
I am unable to determine whether I should either replace the battery, screen, logic board or all of them.
Has anyone ever seen this problem before? What solution did you implement?
Add a comment
Most Helpful Answer
If you want to repair your iPhone, visit these guys they are good at repairing https://fastcellrepair.ca/ they have 6 stores in Canada Vancouver & Burnaby
Score 1
Add a comment
Hi @junaadehb
Start with a screen replacement. The distortion you see on the screen is LCD related and will be fixed from a screen replacement. Some types of LCD damage can also pull additional power, preventing the device from charging normally.
If you continue to have charging issues after the screen is replaced, try a replacement battery. With the age of this device, it is common to see battery failure as well.
iPhone 5s Screen Image
Product
iPhone 5s Screen
$34.99
iPhone 5s Battery Image
Product
iPhone 5s Battery
$29.99
Add a comment
Add your answer
Ab Ba will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 41
