Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1959 Questions View all
Wifi and Gps are very weak, Gsm works fine after opening.
Hey, i´ve opend my 3 gs to replace Batterie and Phone-jack, but now the Wifi and gps don´t work anymore(2.meter range to router..).
I broke the Copper/gold-spring under connctor Nr.7, but I soldered it so it should has good conntact to bezel!
Is this conntact for the Gsm or Wifi/gps ?
Connectors are checked.
What can I try?
Buying a new antenna or is it for gms?
Greets from Germany, Philipp
Add a comment
Chosen Solution
Most likely Connector #6 is loose. Make sure iPhone is OFF before opening and during all repairs. Open iPhone and carefully reseat Connector #6 to the Logic Board.
Comments:
I checked ALL Connectors a dozen of times ;-)
by
Add a comment
Either connector 6 is loose or the connector 6 ribbon cable is damaged.
If it is damaged the part is cheap and looks like this:
iPhone 3GS GPS Antenna Replacement
I bought my replacement on eBay for less than $4 with free shipping.
Add a comment
Add your answer
Philipp Buehler will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,325
