2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
120 Questions View all
MacBook Pro doesn't turn on after keyboard replacement
I recently replaced the keyboard on Macbook pro 13” (early 2013). After the replacement I tried to turn it on and on screen picture said the battery is discharged and that I need to charge it. When I plugged in the T shaped Magsafe adapter the light on it turned on green and Macbook still didn’t turn on or charge. After cleaning the charge port around pins and plugging it in again the light turned amber but there was still the same picture of battery being discharged. I also performed SMC reset when I got the charger working. I decided to leave it be and let it charge, so I didn’t turn it on. When I came back to the computer I saw that light on charger is turned off and when I tried to turn the macbook on nothing happened. And now I’m here writing this in hope someone knows the solution to my problem.
2 Comments
Why did u replace the keyboard, liquid damage ?
by
@arbaman Yes that's correct. It worked fine before the replacement, just the keyboard didn't.
by
Add a comment
1 Answer
Chosen Solution
Liquid damage is deceitful to deal with as where liquids touched components or rails oxidation started and it’s hard to stop, unless one manages to clean and restore parts and circuits at microscopic level with fresh clean metal. It’s not surprising that what worked up to a certain stage it stops abruptly, especially after the board is handled and flexed for removal and repairs. It’s very likely your board is now in need of a deeper charging circuit troubleshooting and a component level repair.
Score 3
1 Comment:
I already got in touch with my friend to troubleshoot charging circuit. Thank you for your answer!
by
Add a comment
Add your answer
zankelenc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 107
