Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Screen black, sound and vibration works
Replaced back cover, mute switch and power button.
Screen is now just black, vibration and sound works.
Itunes detects it, but nothing more.
Score 1
Add a comment
Chosen Solution
Replacing the rear cover requires detaching a lot of ribbon cables and connectors. The connectors in the 3GS are very sensitive and must be connected perfectly or specific components tend not to work (it happened to my friend's speaker a month ago). You should try reopening the device and checking to make sure that all connectors are properly installed. They often times look connected, but a pin or two isn't actually pressed in to place.
If you verify that all of the connectors and ribbon cables are perfectly in place, try having someone call the phone and swipe across the bottom like you would to answer the phone normally. If it doesn't allow you to answer the phone, then the front display ribbon cable is quite possibly ripped or broken.
Try these out and let us know how it goes. Hope this helps! Good luck!
Score 2
Add a comment
ur screen might be jacked up, find an iPhone (thats the same as urs) and switch screens and see what happens
Score 1
Add a comment
Add your answer
Markus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,131
