The 3.5 mm jack receptor is gone. Can I repair it?
The 3.5 mm jack receptor is gone. Can I repair it? It has a blue tooth connector but it must also use the 3.5mm jack that is missing.
@jrosendahl yes it is but the real issue here will be to find a replacement. In the past I just removed the jack and replaced it with a complete 4ft cable. Not as convenient as unplugging it but it kept the headphones working. Check this teardown Bose QuietComfort 35 PARTIAL Teardown about how to get into your headphones. Post some good images of what you find so that we can see what you see and may assist you if needed.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 245
