Repair manuals and support for cars and trucks manufactured by Chevrolet.
797 Questions View all
2004 Chevrolet Avalanche driver side window not working?
Driver side window wont roll down. I can hear the motor turning. Is this a fix that I wont need to take to a repair shop?
Add a comment
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
1 Answer
Chosen Solution
I would at least take off the inside panel and look at the regulator arms. If you hear the motor working when you push the switch you know that all of that is ok. The are regulator arms in the door that move the window up and down. Make sure that the motor is on the regulator arms and that the window is on its track. Also check for the cable that connects from the motor to the regulator arms, it may be frayed or snapped already. There is excellent info on on here. The attached image stems from, that site and show the cable as well as the motor and the regulator arms. Good Luck.
Score 2
Add a comment
Add your answer
Mike Hall will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 106
All Time: 1,900
