This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
145 Questions View all
How do I fix damaged wires by the hinge?
My son's Ninetendo DS Lite's hinge broke. When it broke, it also seems to have damaged the wires that were housed in that area. How do I fix the wires so the system can work?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Kristy,
If the wires are not broken, I believe there is room for you to just use a small amount of electrical tape on each wire. If they are broken you will need some small diameter heat shrink tubing, a heat gun or hair dryer and a soldering iron. Place the tubing over the wires as far away from the solder joint as possible and then carefully solder the wires together. then slide the tubing over the splice and heat it up. Please let us know how you do.
Add a comment
Add your answer
Kristy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 899
