Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1198 Questions View all
Connecting the phone to a charger while in use is preferable
When a charger is connected to a phone while in use:
1. the charger current goes directly to the battery and from the battery to the rest of the  phone? There in no direct connection from the charger to non-battery modules like screen and cpu.
2. Or some of the current goes to the battery to get charged and the rest of the current goes directly to the rest of the phone.
Where im going to is:
1. using the iphone/ipad while connected to a charger will not tax the battery.
2. connecting  the phone to a charger while in use will not degrade and use battery life and is the preferable way  to use the phone as posible.
Add a comment
1 Answer
Chosen Solution
It goes to both because the dock connector is plugged into the Motherboard that goes into the battery
Score 1
2 Comments:
Ok thanks for the answer. It sheds some insight.
Current from the charger does go directly to the peripherals
and results in less drain on the battery.
So, is it useful to use the iPad iPhone connected to the charger, I suppose?
Do android phones peripherals also receive current directly from the charger?
by
Having it plugged in most of the time will preserve the battery life.
The power the phone demands will be drawn from the wall charger. Any extra current available (not needed) will be redirected to the battery to charge it up when needed.
If the phone discharges while plugged into a charger this indicates the charger is either not strong enough or the phone is demanding too much power draw.
by
Add a comment
Add your answer
Camarosspr Camarosspr will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 37
