4-inch iPhone released in March 2016 with similar hardware specifications to the 6s. Available in Silver, Space Grey, Gold, or Rose Gold with 16/64 GB storage options. Model A1662 and A1723.
689 Questions View all
Worked fine but then black screen after waking from sleep
I replaced the screen and on starting up everything worked fine, both the lcd and digitizer. After putting it to sleep, however, it has a black screen. If I disassemble again, undo and redo cable connections, same thing happens. Works fine until you hit the sleep button and then it has a black screen. I put the original/cracked screen back on and everything worked. Used it that way for a couple weeks. Put the replacement screen on again and have the same problem—works until it is put to sleep, then black screen. Any suggestions are appreciated.
Comments:
Thanks for the help, I’ll exchange the part.
by
Add a comment
Android Fix Kits
A new screen or battery is one kit away.
Shop Now
Android Fix Kits
Shop Now
1 Answer
Chosen Solution
If with the old screen things work fine, you have to replace the new faulty screen.
Score 3
Add a comment
Add your answer
robpacker10 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 12
