The Lenovo Yoga 730-13IKB is a folding 2-in-1 laptop produced by Lenovo. It has a 13-inch touch screen and is designed for power users. The laptop can be identified by its model number, which begins with “81CT”.
Keys sticking or not functioning at times
So I have this device come in the shop today with issues with some keys not typing at times, I did blow out the keys with compressed air and that has seemed to help.
Score 3
4 Comments:
Hit the keyboard with air forcing out dust, work slow and take your time till the key starts to function again.
by
If the keys keep acting up I will replace the keyboard, I see the keys on eBay as well as the entire top case replacement. Has anyone attempted this repair and did you get the keyboard or the entire top-case?
by
Done keyboard part only. Very time consuming as you'll need to melt the plastic rivets via soldering iron and remelt it to hold the replacement keyboard in place.
Also need to ensure there is little gap as possible which would indicate a loose area of keyboard due to a rivet need remelting again.
Entire top case would make it easier for repair.
by
Add a comment
1 Answer
Sometimes keys stick because of a drink spill. Try spraying it with tuner cleaner.
Add a comment
Add your answer
Nathan Karstedt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 9
All Time: 2,577
