Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2686 Questions View all
power cable not working on pc
My iphone 6s has been disabled and says i need to connect to itunes. however when i attempt to connect the cable to my pc it does not charge or respond only vibrates 4 times. i have tried multiple cables and multiple pc’s. any help would be greatly appreciated thank you.
Add a comment
1 Answer
Chosen Solution
You may have a faulty lightning assembly..I’d try replace that part as first thing, it’s between cable and board, would be the more reasonable and cheapest repair attempt.
iPhone 6s Lightning Connector Assembly Replacement
Score 2
2 Comments:
do you fell as if this will work because it can charge perfectly fine from any other source?
by
@Harry Weston Of course I can't be sure, but power and data travel on different circuits. It might as well be a board issue but in my opinion it would be worth trying, considering the modest replacement costs. If that wouldn't work, a board repair may be needed. You mentioned trying different cables..hope an original or MFi certified was already tried with the iPhone.
by
Add a comment
Add your answer
Harry Weston will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 39
