Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3215 Questions View all
How do you remove stripped screws from the bottom of the phone?
The screws are stripped at the bottom of my iphone 4...how do you get them out??? :/
Comments:
How did they get stripped?
Are they 5 point or 4 point?
by
someone was going to replace the screen...stripped one and lost the other and now im stuck with this problem and idk what they were
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I use this extractor set: Precision Screw Extractor Set
Score 4
Comments:
thank you. :] ill try it
by
The extractor set is great. In a jam, if you have a cheap -mini flat head screwdriver you might be able to file down the tip to fit inside the screw head to get some torque.
by
Add a comment
if your good with power tools a Dremel is what i used to cut a slot in it for a flat head
Add a comment
You can try this but i must warn you to be VERY CAUTIOUS in what you are doing. I used this method and it was successful for me, but then again, it was a small screw. *I am not responsible for any damage done to your phone* :)
Ok, so i took a power drill and used it on the top screw of the EMF protection shield. The screw was stripped so I took the smallest drill bit i could find that would just fit the circumference of the screw. Then, very carefully screw into it, completely making the screw into a bowl. Next, switched directions of the drill, used a little force and went slow....next thing i know the screw is out. You can try this but just be careful and don't break anything. GOOD LUCK! Let me Know if you need anything else..
Add a comment
Add your answer
Haley will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 23
All Time: 14,460
