First generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
128 Questions View all
Is it the LCD screen or back light?
My son left his iPad in the rain. I let it dry out for a week and put it in dry rice to dry it out (the first 2 days). At first I got no response from turning it on. After charging it over night, I got the charging noise (I unplugged and plugged it in to get that noise). After a few more hours of charging, I got the noise when I turned it on and also a "screen shot" noise. We noticed then, at night with artificial room lighting, "ghost" shadows of the icons. We are able to turn on iTunes and a movie we had downloaded. The sound worked on both of those. The iPad appears to be working, but we are now trying to figure out if it's the LCD screen that is shot or just the back lighting, since we can barely make out the icons in the right light.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Electronics Water Damage
iPad Wi-Fi Logic Board Replacement
take a look at these guides.. they may help you to clean the ipad and keep it going a lot longer..
Score 1
Add a comment
you might have fried the backlight chip or the filter.
if your ipad 1 or 2 was short because you forgot to turn off the ipad when changing the screen.
you want to change and replace
the backlight chip
and the backlight filter
and then if you ipad had water damage change the backlight 4R7 coil as well.
for more detailed picture showing where the ipad 1, 2, 3 backlight circuits is located please visit cyberdocllc
I made a youtube video on the ipad 2 backlight solution
Add a comment
Add your answer
Tiffany will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,613
