will not power up
when i press the power button,the lights come on for a couple of seconds.Then it shuts off.whats the problem with it?
I am including a link to a previous post concerning Dell. Its a different model but I believe may have some use for you. The teardown should be similar and you can check the coin battery for the proper replacement. Good luck.
Inspiron 1526 - Bad motherboards galore
Link to Latitude D620 service manual
http://support.dell.com/support/edocs/sy...
Link to coin cell replacement
i can hold the power button down and it will power up,but when i strike any key it shuts off!Could it be the motherboard?
I'd try replacing the coin cell battery as a first step. If that doesn't clear it get back to us.
You most likely have a dead battery. To check, remove the battery from the bottom of the machine and plug in the power cable. If it powers up, the battery may need to be replaced.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,152
