Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Why iPhone 3GS not turning on,after I connected with wrong car charger
my iphone 3gs battery was completly empty, I tried to charge that from car charger, it did not power up, after that I connected my iphone with USB port of SKY box, but I could see no life in it.
I think I have applied the wrong charging which broke some power socket.
can anyone help
Score -1
Add a comment
1 Answer
Chosen Solution
Hey, Shah. Did you try plugging it in to a wall charger? Often times a car charger or computer USB charger will not charge a phone that has died. Try plugging it into a wall charger for a couple hours, then turn it on. Also try using a different USB cord if the wall charger does not do the trick.
If it doesn't turn on normally after a couple hours of charging, try doing a soft reset by holding down the sleep button and the home button at the same time until an Apple Logo appears.
If neither of these work, it is possible that your battery is dead. iPhone batteries have a limited number of times that they can die before needing to be replaced. Hopefully one of these solves your problem. Good luck!
Add a comment
Add your answer
Shah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,090
