4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1040 Questions View all
I can text and receive messages, but I can’t call or receive calls
Everything else works fine, my phone number is still the same, I can text and receive messages, but I’m unable to call and receive calls.
Score 3
1 Comment:
I called my carrier and they just pushed a button and activated it. Thanks for the help!
by
Add a comment
Which service provider do you have? Have you taken the SIM card out and blown on it and the slot,then reinserted it?
Have you reset network settings in your iPhone?(settings,general,reset,reset network settings)? Have you tried the SIM card in another phone to see if calling works on the other phone?….if so,what were the results? You can also try your family members SIM card in your phone to see what happens.
Is your iPhone up to date?
If you’ve already tried the above,you can always try to factory reset the iPhone and setup as new to see if it works again. If you do this,back it up first!!!! I repeat,BACK IT UP FIRST to iTunes. If this still doesn’t solve it,It’s most likely going to be hardware related.
Network resetting resets WiFi passwords and network cache files. It can solve glitches with WiFi and cellular problems,including calls. Factory resetting it will erase everything,but can solve software glitches in the file system.
Honestly,I’d try the SIM card suggestions first,and network reset. The factory erase reset is a last resort…
Add a comment
maybe your provider network is not working. That is what is happening with me
Add a comment
Phone receives messages but does not receive call,Stylo
Add a comment
Guys, I found the answer.
The problem is that the phone is not selecting the network operator properly or automatically.
All you need to do is go to you network settings and search for the operator. For example? My provider had 2. A LTE option and a GSM option? I selected the LTE and boom. Issue resolved
Add a comment
Add your answer
Cooper Helton will be eternally grateful.
Past 24 Hours: 9
Past 7 Days: 53
Past 30 Days: 242
All Time: 35,620
