Broken Trackpad Ribbon Cable Connector
My dad was cleaning the trackpad in his mac and this connector (not his actual logicboard) quite literally fell off the board (my guess is it had gotten very brittle over time, or was a manufacturing issue.).
I need a replacement connector to solder on to the board. all i can find is the connector for the keyboard, but i need the trackpad connector.
*I do not need the ribbon cable I need the pin connector the cable goes into* where the arrow is pointing
Thank you everyone!
Update! I opened it back up and took some pictures so you can see what I'm talking about! THANK YOU EVERYONE who's responded so far! I appreciate it.
I counted 18 pins on this connector but I can't find anything on Google for “18 pin trackpad connector apple MacBook pro".
2 Comments
If no luck getting the info here you might want to try the following : https://old.reddit.com/r/AskElectronics/
If a search of that reddit doesn't produce any relevant results, then you may feel like fielding your query in that reddit.
Please see the following paragraph posted by the AutoModerator as an example of the information that should be supplied with your query:
https://old.reddit.com/r/AskElectronics/...
by prop man
Are you sure you actually have an Early 2015? I would double-check... That's probably throwing people off a bit.
by Jonah Aragon
