Is it easy to replace display-pmu of iPhone X?
Hello.
My iPhone X keeps rebooting randomly, 3-4 times a day and it takes long time to work normally again. After investigating panic-full logs, I found this message:
checkBusStatus SCL is stuck low; last write status 00000108 int shadow 00010100 xfer 40000000 fifo 00000022 for device display-pmu
Looks like there’s a problem with the display PMU.
Is it easy to replace only this part or will I need to obtain a whole new screen? Phone stores ask for $350++ to replace an iPhone X screen.
Thank you.
/ Updated: The first section of panic-full log:
"build":"iPhone OS 12.4 (16G77)",
"product":"iPhone10,6",
"kernel":"Darwin Kernel Version 18.7.0: Fri Jun 21 22:24:16 PDT 2019; root:xnu-4903.270.47~7/RELEASE_ARM64_T8015",
"incident":"4F9F6D52-6AD0-49AF-B230-C660F3A65753",
"crashReporterKey":"64b11221d0a83ae164b70eb9f98dc321764fd0eb",
"date":"2019-08-25 22:42:38.08 +0700",
"panicString":"panic(cpu 2 caller 0xfffffff01008405c): "i2c3::_checkBusStatus SCL is stuck low; last write status 00000108 int shadow 00010100 xfer 40000000 fifo 00000022 for device display-pmu"@/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleS5L8940X/AppleS5L8940X-166.200.1/AppleS5L8940XI2C.cpp:340 Debugger message: panic Memory ID: 0xff OS version: Not set yet Kernel version: Darwin Kernel Version 18.7.0: Fri Jun 21 22:24:16 PDT 2019; root:xnu-4903.270.47~7/RELEASE_ARM64_T8015 KernelCache UUID: 4E83915BBCAB6C91CDFCDADF90ACE495 Kernel UUID: B1307FDA-64B9-3CAA-893F-082821110C43 iBoot version: iBoot-4513.270.14 secure boot?: YES Paniclog version: 13 Kernel slide: 0x0000000009dc0000 Kernel text base: 0xfffffff010dc4000 mach_absolute_time: 0x1871a9df Epoch Time: sec usec Boot : 0x00000000 0x00000000 Sleep : 0x00000000 0x00000000 Wake : 0x00000000 0x00000000 Calendar: 0x00000000 0x00000000 Panicked task 0xffffffe00037e760: 1296 pages, 196 threads: pid 0: kernel_task Panicked thread: 0xffffffe0006bc000, backtrace: 0xffffffe04ed63260, tid: 200 lr: 0xfffffff010ed291c fp: 0xffffffe04ed632f0 lr: 0xfffffff010fc675c fp: 0xffffffe04ed63420 lr: 0xfffffff010e9d610 fp: 0xffffffe04ed63430 lr: 0xfffffff010ed1ed8 fp: 0xffffffe04ed637a0 lr: 0xfffffff010ed2250 fp: 0xffffffe04ed637e0 lr: 0xfffffff010ed20a4 fp: 0xffffffe04ed63800 lr: 0xfffffff01008405c fp: 0xffffffe04ed63890 lr: 0xfffffff010083c1c fp: 0xffffffe04ed638c0 lr: 0xfffffff010083920 fp: 0xffffffe04ed638f0 lr: 0xfffffff00fd3f778 fp: 0xffffffe04ed63910 lr: 0xfffffff00fd3f5e0 fp: 0xffffffe04ed63940 lr: 0xfffffff01137fc74 fp: 0xffffffe04ed639b0 lr: 0xfffffff00fd400e8 fp: 0xffffffe04ed63a10 lr: 0xfffffff01051a2d8 fp: 0xffffffe04ed63a60 lr: 0xfffffff01051a240 fp: 0xffffffe04ed63aa0 lr: 0xfffffff01051aa9c fp: 0xffffffe04ed63ad0 lr: 0xfffffff01135d138 fp: 0xffffffe04ed63b20 lr: 0xfffffff01135cf1c fp: 0xffffffe04ed63bb0 lr: 0xfffffff01135c44c fp: 0xffffffe04ed63c20 lr: 0xfffffff01135e134 fp: 0xffffffe04ed63c90 lr: 0xfffffff010ea86b4 fp: 0x0000000000000000 ",
"panicFlags":"0x2",
3 Comments
And here is the first part of the log:
by Phuong Nguyen
Might also want to check out/search the following for possible answer to your question:
https://old.reddit.com/r/mobilerepair/
by prop man
@phuongn replace screen fixed your problem? i`m with same problem on iphone XS Max
by edson29junior
