Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
834 Questions View all
2009 MacBook Pro won't dim or go to sleep why?
Hi guys,
Everytime I close the lid on my macbook pro the screen would remain on and not dim or go to sleep.
On two occasions the battery just ran out and the system was very hot.
What can I do to fix this issue?
I just replaced my logic board 5 days since my old board usb ports was going bad.
I tried resetting all the cables inside twice to see if something is not connected but I am still having the issue?
Guys could it be a damaged logic board from Ifix it or is there a particular cable or setting that does it
Thanks?
Comments:
Please give us the last three figures of your serial number so we know exactly which MacBook you're working on. Thanks
by
its a 2009 macbook pro unibody 2009 version last three digits are 66d
thanks like always mayer :)
by
Apple MacBook Pro "Core 2 Duo" 2.26 13" (SD/FW) Specs
Identifiers: Mid-2009 13" - MB990LL/A - MacBookPro5,5 - A1278 - 2326*
by
Add a comment
1 Answer
Chosen Solution
Check your connections on the sleep sensor cable. If damaged, replace it. Here's the cable: http://www.rsparry.com/lcd-cable-flex-ca...
Score 3
Add a comment
Add your answer
johnnysrivera will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,025
