Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Questions View all
Why won’t my MacBook Pro charge properly?
Hey forum,
Earlier today I tried to hook my MacBook Pro 13” Mid 2010 to an external monitor. The monitor was plugged into a surge protector, and my DVI cable was plugged into the Mac. As I tried to plug the other end into the monitor, an arc formed between the DVI connector and the cable. Long story short, this killed the Magsafe charger I was using. I tried to plug my backup into the Mac, but the Mac wouldn’t accept a charge, and the Magsafe light was stuck on green.
I tried to reset the SMC several times, but it hasn’t worked. And now I can’t even get into the Mac because the battery died.
Any thoughts on how to fix this situation? Like I said, I tried the SMC reset several times, but it hasn’t worked. Thanks in advance?
Add a comment
1 Answer
Chosen Solution
If you’re sure the Magsafe you’re using is good, your Mac should start with battery unplugged. If it doesn’t some component of the logic board got burned when you got the spike. Probably the only way to fix it is through a component level repair.
Score 1
1 Comment:
@arbaman - Sounds like a fake charger issue ;-{
Many of these fakes don't have proper grounding.
FYI: Don't Replace Your MacBook Charger With a Cheap Knockoff Here's one example between the two Counterfeit Macbook charger teardown: convincing outside but dangerous inside
by
Add a comment
Add your answer
Gordon Hall will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 40
