Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3252 Questions View all
Is a iPhone 4 logic board needed?
right guys,
i fitted a white conversion kit last week and the phone would turn on fine, connect to itunes fine ect, it was low on charge so i went to charge it via laptop and wall sockets and no luck, i then remembered when i was putting the phone back togeather my brother lost a wee part that goes next to the battery connector. after research i found out it was a Logic Board Battery Connector Bracket, picture link under neath. i was wondering if that was why the phone was not charging as that is the only thing missing/wrong? thanks for your help guys !
stefan
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Yes, yes, yes!
The logic board is your power management brain. I am surprised that you have had such good success so far without it. Apple calls their motherboards, "logic boards" but it does the same thing. So essentially you are using a phone without the motherboard installed. The processor, and most of the sensors are separate in the iPhone (compared to laptops where the logic board contains just about every major part besides RAM and a Harddrive), but it is still mainly there for power management.
Now it is different from the battery and the power supply charger, so they still will work at some very low level, depending on what they were doing when you disconnected it, but you will have major problems charging it and possible sensor communication errors.
The $10 fix will be well worth it, otherwise you might as well get used to using your phone plugged into the wall.
Comments:
thanks for the comment and info ! so if i'm correct.. with that fitted the phone should work like normal?
thanks allot for the help.
by
Add a comment
Add your answer
stefan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 719
