After Headphone Jack replacement: Headphone mic not working
I had to replace the headphone jack because of a faulty mute switch.
I had a lot of scratches on the back of the phone, so I thought it might be a good idea to replace the rear panel as well.
After installing the new parts (thanx to ifixit!!!) everything was working except for the headphone mic and the headphone volume buttons.
My fist thought was I've bought a faulty headphone jack flex cable. So a disassembled the whole thing again, replaced the jack with another one - only to find out that I have the same problem.
Thinking that it is very unlikely that both parts are faulty I connected the no. 5 connector of the flex cable i just took out (the first replacement part not the original one), plugged my headphones in and guess what: Mic and volume buttons are working. So everything is working when the flex cable is not fitted into the phone, but once it is fitted mic and volume buttons are not working.
Any ideas?
I would very much appreciate any help!!! :-)
6 Comments
bit confused.. there is no mic on the headphone jack...
perhaps you have the metal backing overlapping incorrectly at the point where the volume and mute switch joins...it's held by a small screw.
by pollytintop
I gave it my best shot to see about helping
by Nick
Maybe I did not make the point clear enough.
The microphone on the headphone is not working (and the two buttons beside it). Headphone is working with another iPhone 3Gs - so that is not the problem. And: Headphone-Mic is working when the headphone jack flex cable is not fitted to the rear panel. So the parts are O.K. - But not working when everything is reassembled...:-(
by Georg Keiner
nick good shot.. in this case the logic board can't be the problem as the headphone works when the flex is connected but not installed in the case, it can't be the flex because that too works. the only thing left to be at fault is the assembly process. A photo here might help us eh?
by pollytintop
Here are links to pictures. Could the problems be related to grounding or some kind of short cut caused by the bezel. The rear panel is not an OEM one but a very, very good third party version. Thanks again for the help!!!
https://picasaweb.google.com/lh/photo/O_...
https://picasaweb.google.com/lh/photo/ab...
by Georg Keiner
Show 1 more comment
