Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
265 Questions View all
Help 4l60e constant shifting
97 chevy 5.7l vortec. Backfired through intake and blew pcv valve line off the intake. Drove it 20 miles not knowing it was off, abnormally high idle. Reconnected line now i get a back and forth 3rd to 4th gear shift. Rpm amd speedo jump around when this happens. Rebuilt trans 6000 miles ago. Tested all solenoids in tranny, all good. No Cel no stored codes. Any ideas? Thanks
Comments:
Also it doesnt always do this, sometimes it does perfect. Other times it does it right off the bat from first start up.
by
Add a comment
1 Answer
Most Helpful Answer
Hey Lee.
Could be throttle position sensor issue (harness and/or wiring included). Throttle plate could have carbon buildup around it’s edges, as well. Also make sure vacuum lines and connections are sound.
Hope this might help.
Score 2
Comments:
It did throw a tps code 1 time and 1 time only. Erased it and it hasnt came back. I will replace the tps and see what happens.
by
Add a comment
Add your answer
Lee stevens will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 32
